Signing into plusnet
laraineq
Can anybody give me any help with signing into my account? All I get when trying is that my username/email or password is incorrect. I can’t even change my password
3 REPLIES 3
outcast
Aspiring Champion
Fixes: 19
Re: Signing into plusnet
I don't have a suggestion that helps Embarrassed
but I can tell you that the "Member Centre" portal login IS currently working, so there isn't a wider login problem, it's just you.
I was actually surprised that MY login worked, as I left Plusnet two years ago, but apparently I can still access my account.
Good luck with finding an answer !.
Fixes: 391
@laraineq To sign into tour Member Centre, you just use your username - if that is for instance for you 'laraine' , then you put that in the top box, and your password is that you agreed with PN when you set up the account. NOTE: both are case sensitive.
Fixes: 1,495
Moderators Note
This topic has been moved from Broadband to My Account / Billing
