Setting up Power of Attorney
Glengavel
Good afternoon, my father has moved into a care home and I need to cancel his Plusnet account. Is there an email address to which I can sent the necessary Power of Attorney document?
Regards,
Robert
3 REPLIES 3
Fixes: 579
Re: Setting up Power of Attorney
Unless anything has changed since 2020...
You can do this by using the options below
  • Scanned and sent via email to [email protected]
  • A photocopy, sent by letter, to the following address:
    • Plusnet PLC
      The Balance
      2 Pinfold Street
      Sheffield
    • S1 2GU
If you have a recent LPA and have the ability to generate an 'access code' ( https://www.gov.uk/view-lasting-power-of-attorney ) then I believe Plusnet can accept that and will be able to use that to view the LPA
Fixes: 1,662
That's correct, except we've moved! New address is:
Plusnet Plc
Endeavour
Sheffield Digital Campus
1a Concourse Way
Sheffield
S1 2BJ
This information is here.
Glengavel
Thank you, I will give the email address a try.
