Router return
GaryKK
Router return
Hello,
My contract with Plusnet was just terminated and I'm supposed to return the router.  I did it yesterday but today I find that I have returned the wrong router (that was not from Plusnet).  I checked with the post office and they said the device is already on the way.  Is there anyway I can get back the wrong router and send the correct one?
3 REPLIES 3
markhawkin
Champion
Fixes: 22
Re: Router return
Does it matter much?
Do you want the router you posted?
If it's an old ISP router it won't have much value.
As long as you have the one that works with your new service I guess that will be OK.
GaryKK
Re: Router return
Thanks for your reply.  What can I do if I want to have it back?  It's a router I borrowed from someone, and it looks very much like the one from Plusnet so that's why I made the mistake.
markhawkin
Champion
Fixes: 22
Re: Router return
Aah, I see the difficulty.
You could try phoning up but I'm not optimistic.
