Router Return - Timescale
davidb1901
Re: Router Return - Timescale
As I joined about a week ago it will be subject to charges.
Returned routers are found here
https://www.plus.net/member-centre/account
Returned routers
You can easily check the routers you've previously sent back to us.
See
Where it states
Why it’s important you return our router
Returning our router helps us to reuse any parts or dispose it in the most environmentally friendly way.We can also help you return it to us for free.
Joined us after 1 Feb 2024?
Don’t forget, our routers are provided on a loan basis, so it’s really important they’re returned to us when no longer needed.Just a gentle reminder, if you don’t return our router, you’ll be charged a £50 fee.
Where my router is still showing
Your devices and return status
Router in use
Current active router:
Plusnet Hub Two FTTP
Hence the post.
I have asked Plusnet to fix this.
Fixes: 387
OK
davidb1901
Just had a chat with plusnet. Basically the router needs to appear against the account details, however, they will email me confirmation that it has been returned.
