Product change in progress
Nonplussed9
When I login to my account I get the message below even though the last change to my broadband was made over 4 years ago.
An error has occurred
You can't change your products for the moment, you already have a product change in progress.
I see other people in the forum have had similar issues and had them fixed with the help of one of the Staff members.
Thanks in advance....
5 REPLIES 5
Fixes: 1,662
Re: Product change in progress
Hi @Nonplussed9,
I've fixed this for you, let me know if you have any issues.
(edit)
Actually I don't think this is fully fixed as there's still a stuck change from what I can see. We're looking into it further and will get back to you soon.
(edit)
Now it should be fixed. Smiley
Nonplussed9
Thanks Gandalf.
That's all working again now.
Nonplussed9
Hang on, maybe I spoke too soon.
Now I can login to the Member Centre but I can't login to my catch-all email via Webmail. My email client keeps trying and I get popups appearing every 10 minutes or so telling me it's failed.
After the Member Centre got fixed I logged into my mobile account for the first time and my password manager got a bit confused between the Member Centre and the Mobile Login. I straightened them out creating new passwords in the process, but now the catch-all email does not accept the new password for the Member Centre even when I take my email client out of the equation and try to login via Webmail.
Is this one you can fix?
adamwalker
Fixes: 223
Hi there, mailboxes can sometimes lag behind when the main account password has changed, have you tried since yesterday evening? - Adam
 Adam Walker
Nonplussed9
Just tried it. This time when I gave it the new password it accepted it
Thanks, I guess patience is a virtue.
