Independant Static IP
woodyknows
Hello, given that Plusnet do not issue static IPs anymore, I have purchased one elsewhere. How do I get Plusnet to apply it to my account?
Tags (3)
2 REPLIES 2
Fixes: 250
Re: Independant Static IP
"I have purchased one elsewhere"
Can you explain that?  Have you purchased a VPN provision?  If yes then you connect via their VPN service.
Naked IP addresses are managed by the ISP / connection provider, not a third party.
corringham
Seasoned Champion
Fixes: 23
The way to do this is, as @Townman says, is to set up outgoing connection using a VPN or L2TP tunnel to a host - your static IP address is then published and will use the tunnel to connect to your machine.
This should work with any ISP - even with a CGNAT connection (e.g. over mobile phone) - although some issues can be caused as some sites may refuse a connection if the VPN host has a poor reputation or a geo-location that isn't accepted.
