How do you check your sim account has eu roaming enabled
Marand
I can’t see anywhere that confirms roam like at home is active on either of my sims.
where can I find confirmation of its status rather than just assume it’s on and find out it’s not only when I leave the uk.
thanks
2 REPLIES 2
Fixes: 466
Re: How do you check your sim account has eu roaming enabled
Moderators Note
This topic has been moved from Mobile Tech Help
Fixes: 1,652
Unless you have an account with us from the legacy Life Mobile days (pre-November 2016) and someone's not fiddled about, you should have Roam like at Home automatically enabled.
If you can private message me your full name and mobile number though, I can check for you. Smiley
