How do I reply to a Question previously raised?
markv
As so often happens, when I renewed my Plusnet Broadband, the billing was a total mess.
I mentioned my problems hereabouts and question 228434329  was raised.
That did not solve the problem but I can't see a way to post a response, even after I have logged in.
The issue is so complicated (I spent most of this afternoon writing up a summary and it's half a page of A4).
No way a chatbot or online agent is going to take that onboard.
So how do I send my findings to Plusnet?
6 REPLIES 6
Fixes: 374
Re: How do I reply to a Question previously raised?
@markv When was the Question raised/last replied to?
markv
@jab1 question 228434329  was raised, and replied to, on 17/10/2022 15:53
Mark
Fixes: 241
In that case, it will have closed automatically (unless it is still with Plusnet on hold).
Hopefully a staff member will pick up the issue for you here...
Fixes: 374
In that case it will be closed. Tickets only remain open for 14 days from the last reply.
markv
Noted, thanks.
I tried replying to the last email I received on the subject from Plusnet Customer Support [email protected]
Auto-reply saying, "Unfortunately we don't pick up any emails sent to this address."
Interesting.
Anyway, had to phone up and explain the lengthy circs verbally. Hopefully will be sorted.
Mark
TheMightyAJ
Fixes: 126
Hey @markv,
Thanks for reaching out to us. I can see that you've spoken to support and this should now be sorted, but if you have any further queries or issues then please let us know and we'll be happy to help Smiley
 Alex H
