Home phone number has been changed when it shouldn’t have
Anneshaw
I have to switched to plusnet landline and broadband. The broadband is working but my landline number has been changed.
It is very important that I get my old landline number back as a priority.
6 REPLIES 6
Fixes: 466
Re: Home phone number has been changed when it shouldn’t have
Moderators Note
This topic has been moved from Home Phone to My Account/Billing.
Fixes: 466
@Anneshaw
If you are not to.lose the number you need to move quickly on this. If you don’t get a Plusnet staffer to pick this up fairly quickly then you should ring in.
Anneshaw
Can a staff member sort this out
adamwalker
Fixes: 223
Hi Anne, I can help with this. Can you send me a private message with your username and the phone number you wanted to move across to us please?
 Adam Walker
Anneshaw
Thanks for your reply.
When I go to the private message section it says access denied.
adamwalker
Fixes: 223
Hi Anne, you need to have made at least 3 posts on the forums so if you try again now it should work.
 Adam Walker
