Help a noob….
disgracie
Help a noob….
I have unlimited fibre extra (no complaints-free line rental etc) I pay £27 ish. Got an offer to upgrade to plusnets “new fibre package” for 24 month contract, no phone line required. For £26.
Can someone be so kind as to explain the difference between the two packages? They both quote the same speed. How does the new package work without a phone line? Like how does it connect back to the cabinet?? Surley it’s not full fibre to the premise as I would expect a massive increase in speed for that.
Any ideas?
5 REPLIES 5
Fixes: 381
Re: Help a noob….
Personally, if you still use a landline phone, I would ignore the 'offer'. The connection is exactly as at present, but for the princely discount of £1.00, you won't have a fixed-line phone service.
Fixes: 476
Re: Help a noob….
@disgracie
No landline is a misnomer. There is still a copper line from your property, what is no longer provided is a landline telephone service on that line.
Moderator’s Note
This topic has been moved from General Chat to My Accounts/Billing
Fixes: 115
Re: Help a noob….
@disgracie
Have a look at the following
What's in the left hand column - FTTC is VDSL and FTTP is WBC FTTP
Full fibre requires a new fibre cable to be laid to your property. I assume you're on a 78/20 product. The FTTP equivilant is 74/20. If you so desire you can get 145, 300, 500 and 900 down.
PN do not offer a phone service with FF. If you use a landline or your number is important to you you'd need to set up a VOIP account with a VOIP provider.
RealAleMadrid
Fixes: 68
Re: Help a noob….
@bmc  This is nothing to do with Full Fibre (FTTP). It is Plusnet's fairly new (for them) SOGEA offering, i.e. FTTC with no phone service on the line and a massive saving of £1 a month. I have the same offer in my upgrades tab in the member centre. I will not be snapping it up.☹️
Fixes: 381
Re: Help a noob….
Neither would I be at that price.
