Fibre installed tomorrow but no router sent
Soolong
HI, I am having Fiber installed tomorrow morning but according to the members center page on my account no router has been sent out yet, it shows payment made and that Hardware dispatch pending. If the engineer comes out and i do not have it will the installation not go ahead? worried that even if it gets sent today because of the bank holiday causing delays it will not turn up till Friday.
6 REPLIES 6
Fixes: 396
Re: Fibre installed tomorrow but no router sent
Your router may arrive today/tomorrow as sometimes the order tracking can be a bit slow to update.
No, the engineer will still install the modem and test to that. If you still don't have the router then you can connect a single PC directly to the modem using a direct pppoe connection. See here http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows... and here http://community.plus.net/library/broadband/fibre-help-setting-up-a-pppoe-dialler-for-windows-xp/ for details of how to set that up.
Hope that helps
Soolong
Thanks, good to know. I do still have the router from bethere which i do not have to send back just yet so i assume i can use that in the mean time if it is late turning up. Sneaky edit: only realized that after looking on other threads on here.
jelv
Fixes: 10
If it's a normal ADSL router it probably won't work without a firmware update and significant reconfiguring - and depending on the model may not even be possible.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Soolong
Its a Thomson TG585 v7 but it is on its why out, it works ok but it keeps changing its address that i use to reach it via a web browser. its a pain but unless i am adding a device to the wifi network i do not need to touch it. All redundant mind as i am sure (fingers crossed) the plusnet one will turn up tomorrow/today.
Fixes: 396
It IS possible to reconfigure a TG585v7 to use LAN port 4 as a WAN port using a pppoe connection but it's not a trivial task. You can upload a template file to it and then use the built-in setup wizard to reconfigure it. See information here http://forums.modem-help.co.uk/viewtopic.php?t=9301 for help on templates. I believe the template you will need is MH_FIBER_ppp_5xx-7xx-p4.tpl extracted from this download http://download.modem-help.co.uk/mfcs-A/Alcatel/Modems/TG585/v7/Wizards/Setup/Windows/EN/setup-wizar... .
Soolong
Thanks for the info, have saved the page and downloaded the template just in case.
