Extras....Phone Bill
- My Account/Billing
- Re: Extras....Phone Bill
- « Previous
- 1
- 2
- Next »
25-08-2010 11:14 AM
Not sure why it's on your account. I suspect it was a mistake by the agent over the phone when putting your order through. You won't be billed further for it though.
Kelly Dorset
Ex-Broadband Service Manager
Message 16 of 18
(246 Views)
25-08-2010 8:51 PM
Ok, thats the voicemail sorted. Now can you explain about my referral that still outstanding from 01/07/10 of £1 per month.
Message 17 of 18
(246 Views)
26-08-2010 10:14 AM
Hi liqueur,
This has been caused by a problem with referrals that we have at the moment. Internal problem 63080 is open and under investigation. I can't really give you a time frame for a fix at the moment I'm afraid but bear with us as I've set my self a prompt to contact you once this has been resolved.
Adam.
Adam.
Message 18 of 18
(246 Views)
- « Previous
- 1
- 2
- Next »
