Domain Transfer
richlunn
Domain Transfer
Hi
I am looking to start the process of moving our 4 domains to Hostinger, using the least used one as a trial run.
I have seen that @willcutforth  has helped other users with this, maybe you could be of assistance in setting the IPS tag for me.
Rich
12 REPLIES 12
willcutforth
Fixes: 100
Re: Domain Transfer
Hey there @richlunn I'm happy to help. I have created a ticket on the account just so that I can sort this for you. https://www.plus.net/wizard/?p=view_question&id=232005494 is the link for it.
 Will Cutforth
richlunn
Re: Domain Transfer
Thanks @willcutforth , i have responded to the ticket.
willcutforth
Fixes: 100
Re: Domain Transfer
Raised that for you now Rich Smiley should be sorted within the next couple of days then we can look at the other ones for you.
 Will Cutforth
willcutforth
Fixes: 100
Re: Domain Transfer
Should all be sorted for you now Smiley Let me know if not.
 Will Cutforth
richlunn
Re: Domain Transfer
Yes thanks @willcutforth all seems to be up and running fine.  I’ll be in touch shortly when we are ready to pull the trigger on the other domains.
richlunn
Re: Domain Transfer
Hi @willcutforth  We are ready to transfer our other domains in turn now, can you open another ticket for us please?
adamwalker
Fixes: 222
Re: Domain Transfer
Hi Rich, I've just opened a new ticket for you: https://www.plus.net/wizard/?p=view_question&id=232985547
Please drop us a reply back on here once you've responded to it.
Adam
 Adam Walker
richlunn
Re: Domain Transfer
Hi Adam
Thanks for the response, I have replied to the ticket.
Rich
richlunn
Re: Domain Transfer
Hi @adamwalker
I forgot to tag you, I have replied to the ticket.
Rich
csmith94
Fixes: 31
Re: Domain Transfer
Hi @richlunn - I've got this sent off for you now and the domain will be transferred within 3 working days Smiley
 Curtis Smith
jopett
Re: Domain Transfer
Hi
I also need help with transferring out two domain names - can you help me too please @willcutforth ?  I have no technical knowledge at all - do I need to have somewhere ready for them to go before putting in a request?  One site I looked at mentioned having a transfer code?
Thank you!
Jo
adamwalker
Fixes: 222
Re: Domain Transfer
Hi @jopett I've just sent over a private message, please drop me a reply when you can with the domain names and I'll help out. - Adam
 Adam Walker
