Contact number not working
Canale1991
Hi
Everytime I try to call them it says there not open for the festive period?Huh
Can anyone advise.
22 REPLIES 22
Fixes: 479
Re: Contact number not working
@Canale1991   Welcome to the Plusnet Community Fora.
Which number are you ringing/which department? 0330 1239 123?
Is there anything that we can help with on this forum?
Canale1991
Hi yes that's the number I've tried.
It's the billing department I'm trying to reach.
Fixes: 479
Moderator's note:
Thread moved from Broadband to My Account/Billing
Fixes: 580
AFAIK Billing only work normal office hours Mon-Fri. I dont know for sure, but there's a pretty good chance they don't work Public holidays.
Canale1991
Can anyone advise a number that's working please?
Fixes: 383
The 0330 number works. At what point do you get that strange message - as soon as you dial it, or when you select the billing option from the menu?
Canale1991
It rings and then I get the message
Canale1991
It says "as its the festive period our opening hours have temporarily changed"
Fixes: 383
Do you mean that you can select the billing department, and then you get the message? If so, they (billing) are obviously not manned today, it being a public holiday.
Fixes: 383
I have just checked, and got straight through to the department. Can you try using a different mobile - or even a landline?
Canale1991
That's so strange? Can you send the exact number you tried and unfortunately I don't have another phone to use.
Fixes: 383
It was 0330 123 9123
Canale1991
It's still doing it, soon as i get the opening hours message it hangs up
Fixes: 383
The only thing I can think then is that somehow the call is being wrongly routed. Who is your mobile provider?
