Contact number not working
Fixes: 528
Re: Contact number not working
@Canale1991 If you are calling from the phone number registered on the account, then sometimes the IVR can do 'odd' things.
@jab1 wont have that problem because he doesnt have a PN account.
Try withholding your number. On a landline , dial 1470 before the number, on a mobile I think its #31# before the number ( but not sure )
Fixes: 334
Hadn't thought of that, @MisterW - maybe that could explain the odd times this has happened before.
Fixes: 528
It does route the call differently when it detects a call from the registered number. TBH it should still work but if there's a 'glitch' in the system then withhiolding MAY work.
Canale1991
Im with giff gaff
Fixes: 528
@Canale1991 in that case the #31# prefix should work https://community.giffgaff.com/d/23400217-hi-how-do-i-withhold-my-number-on-giffgaff
RobPN
Fixes: 13
Don't you remember this post last month @jab1 ?
Same solution which enabled you to get through!  Wink
Fixes: 334
@RobPN Now you come to mention it.... 😀
Fixes: 528
For info, I just tried calling from the number registered on my account and certainly got the IVR menu.
Ah! just thought @Canale1991 is the reason you are calling billing that your account has a payment failure ?
I think calling from the registered number MAY cause a call to be routed straight to billing.
