Compensation for delayed activation.
Chuddie
As you can see in the screenshot my internet was supposed to be activated on the 6th of August.
It didn't become active until the 22nd of October.
l've brought this up a number of times before and not received a satisfactory reply.
Where's my compensation?
18 REPLIES 18
Fixes: 480
Re: Compensation for delayed activation.
@Chuddie   Welcome to the Plusnet Community Fora.
Did you ever receive an email confirming the activation date and a morning or afternoon appointment. Your attachment looks like it might be an estimated installation programme, rather than a confirmed appointment.
Fixes: 251
What happened between the 6th August and 22nd October?  Was the 6th August a CONFIRMED DATE or a provisional date?  What is the connection type - FTTP?
There can be semantics between this being a delayed activation and it being a fault found upon activation.
Was the cause limited to just your service or were others in the locality impacted?  Compensation for an issue associated with a MSO (Multiple Service Outage) failure is not processed automatically therefore, the user needs to contact support.
If this is being processed automatically, then that might take up to 30 days following the end of the delay.
Ofcom Automatic Compensation Scheme
Plusnet is signed up to the Ofcom Automatic Compensation Scheme - see Automatic Compensation FAQs. Plusnet will pay automatic compensation in the following circumstances:
  1. Delayed activation of your broadband and/or landline service
  2. Delayed repair following a total loss of service
  3. Missed appointments
For compensation to be paid (as a credit to your account), you must have a CONFIRMED date for the failed activity. Compensation is credited within 30 days following the resolution of the issue giving rise to the claim.
To see what is happening in detail, check the ticket history on your account - log into the portal in another tab, return here and click the PN TICKET link below. Look at the details of the tickets; if there appears to be no activity after the due date, contact support.
Note: Outages arising from a Major Service Outage (MSO) event need to be processed manually, so you might need to contact support.
RealAleMadrid
Fixes: 68
@Baldrick1   It states  "Engineer appointment Completed on the 5th of August"  Unless that was the first part of a 2 stage installation.
@Chuddie  What happened on the 5th August did Openreach complete the job and install the ONT in your property?
Then what happened between then and October, seems a very long time, did you have further Openreach visits?
Chuddie
l received an email on 22/07 saying this
You've chosen 05-08-2024 for your engineer appointment between 08:00 - 13:00. We'll aim for this, but our suppliers will need to carry out some extra checks on how the necessary cables can be installed to your property. Depending on how long this takes, the requested appointment date may not be available, however we'll monitor your order and email you to keep you updated on its progress and will confirm your engineer date via email as soon as we can.
After this the install and activation date was pushed back to approximately the end of August, then again to the end of September, then was finally activated in October.
l've had extended conversations with plusnet support about this but unfortunately the ticket has been closed, however if it is still accessible you can find all of the relevant information there.
Chuddie
Openreach came on the 5th of August and said they won't be performing the installation. It was then constantly delayed with openreach doing a little bit of work at a time until the visit into my home to complete the line on the 22nd of October.
l don't really see how this is relevant as Plusnet are the ones who l have a contract with, as l was previously told that my compensation was for some reason dependant on the compensation Openreach will be paying Plusnet.
l'd really like this resolved before my next bill goes out, as over two months of delays should result in a substantial amount of compensation.
Fixes: 480
This is stated to be an aspiration to meet the requested date, not a commitment. Unfortunately, as I read it, this does not fall within the criteria for automatic compensation.
RealAleMadrid
Fixes: 68
@Chuddie  I don't think Plusnet can deny that your activation was delayed so some form of compensation should be payable. As for a confirmed date, this is a somewhat grey area, the whole thing is down to Openreach allowing FTTP orders to be placed when their infrastructure is nowhere near complete.
There is another post on the forum today in a similar situation where a customer is stuck waiting for Openreach to install a new pole and carry out ducting work. Order delayed
The fact that Openreach appeared on the 5th of August and did nothing is interesting, the installers were probably assuming that the infrastructure was ready and when they discovered that nothing was in place they obviously couldn't do anything. This is typical of the mess ups that occur with Openreach.
I would say you should start the clock from that point, as Openreach showed up it must have been a confirmed appointment.
All the replies on this thread so far are from Forum users, not staff so we have no access to your account or ticket details.
If Plusnet aren't cooperating I would use the complaints procedure. Best of luck
Complaints Procedure
Fixes: 480
@RealAleMadrid wrote:
@Chuddie
I understand your point. I still suspect that because of the mess it hasn't triggered automatic compensation, but agree that as they turned up on the chosen day it's worth raising a complaint.
Fixes: 251
The automatic compensation system has until the 21st November to process this automatically ... for whatever number of days the installation was delivered after the committed date.
  • Until the 30 day compensation credit payment window has expired, we do not know if this is or is not within the scope of the scheme ... but has failed to be processed
  • In the absence of a confirmed COMMITTED date we do not know where day zero is
The communication suggests that the date given is one aimed for, but not explicitly committed.  The attendance of BTOR on that date to install the ONT might be inferred as a commitment, but installation of the ONT before the CSP has been installed is not unheard of.
Chuddie
Well it looks like l haven't been automatically compensated, what should l do now?
Fixes: 251
Have you checked the tickets on your account?
Looking at your earlier posts and conjoining information from SU’s discussions…
“We'll aim for this, but our suppliers will need to carry out some extra checks on how the necessary cables can be installed to your property. Depending on how long this takes, the requested appointment date may not be available, however we'll monitor your order and email you to keep you updated on its progress and will CONFIRM your engineer date”
This was a KCI Assure installation to be followed up by a CONFIRMED DATE communication. You have made no reference to being given a CONFIRMED DATE for a one-stage installation.
Chuddie
There are no tickets on my account that l can see.
l find it very odd that Plusnet will almost certainly be being compensated by Openreach for the delay, yet none of that is passed on to me.
lt would be very helpful if a Plusnet staff member could read through the notes of my installation and properly explain to me why l am not being compensated despite the delay. l assume the lack of compensation is due to an error in communication.
l don't know what this means, what l do know is that l was strung along for months with dates until the service was finally live.
Fixes: 387
Chuddie
Thanks.
l did find this
Service Notification
6:06am, Tuesday 23 Jul 2024
An update report has been received for this account.
The broadband order is being processed by the supplier.
The activation will complete by midnight on 05/08/2024.
