Check your bill
redsox9
Fixes: 4
Check your bill
Just alerting you to check your monthly Plusnet bill. My October bill was 36 per cent higher than it should be. A quick call to Accounts sorted it out.
2 REPLIES 2
Fixes: 383
Re: Check your bill
TBH, if you don't check it, it is your look-out.
Fixes: 479
Moved:
Re: Check your bill
