Change account username?
andy_wfuk
Hello
Is it possible to change the username associated with my plusnet account (not forum, the actual account)?
I now have a static IP and I noticed that the reverse lookup on this points to [my_username].plus.com
Unfortunately, I have used much of my real name for the username, so it's not exactly ideal from a privacy or security point of view.
5 REPLIES 5
Fixes: 558
Re: Change account username?
@andy_wfuk
In a word, No.
It is however possible to request that the rDNS is changed to <ip address>.plus.com.
You could either start a new thread or hope that a staff member responds here
andy_wfuk
Thank you, hopefully a staff member will see this and change my rDNS.
adamwalker
Fixes: 223
Hi @andy_wfuk What would you like us to change that to?
A common thing if you just want the username redacted is to have it as "IP".plus.com
 Adam Walker
andy_wfuk
Hi @adamwalker
Yes please, [my_ip_address].plus.com would be great.
Many thanks
adamwalker
Fixes: 223
Cheers, I've raised a task for you and that should get picked up within the next 5 working days
 Adam Walker
