Card Payments error using Firefox
- My Account/Billing
- Re: Card Payments error using Firefox
- « Previous
- Next »
20-12-2014 10:05 AM
Quote from: Anotherone What about Control Panel >Regional and Language options. Is it all set to UK and not customised incorrectly in some way?
Check >Regional Options >Customise >Numbers >Display leading zeros
Numbers set to 0.7 rather than .7 - so that's OK All other settings in Win 7 set to UK etc.
20-12-2014 10:18 AM
Quote from: kmilburn Regarding the screen-shot, you're not missing the mm, you just need to expand the 'option' to see it.
Ultimately, the reason Firefox is displaying the wrong thing is that it's receiving the wrong thing, which would imply something is intercepting and modifying it.
Another thing to check would be the proxy settings in preferences, advanced, network, settings. usually there's no need for a proxy on a home network, and some malware changes the setting.
Additionally you can investigate what the browser is seeing using the 'Developer Tools' network option, or if you want to get adventurous, you could install wireshark and use it to see what's happening at the network packet level.
Firefox is set "use system proxy settings "
so why would all be be OK on IE on same PC and even correct using Firefox for Android on a a tablet on same home network?
Will try another PC running Win7 + FF34 on same network later and report back................
20-12-2014 2:03 PM
So despite using in safe mode it must be a problem with my Firefox setup..............
20-12-2014 2:05 PM
Quote from: kdhuk it must be a problem with myFirefox setup..............
Not exactly novel then!
20-12-2014 2:45 PM
20-12-2014 2:55 PM
20-12-2014 3:02 PM
Quote from: Townman Not a problem with the PlusNet system, but users (defective?) browsers?
So how do you explain this ? -
Quote from: kdhuk I might add I only ever have this problem with drop downs on PlusNet - not on any other payment sites using Firefox
20-12-2014 3:16 PM
The poster has identified that the same back end system produces different results on their different platforms. Those that fail have a common configuration element - FF profiles.
Other sites might be using different technology, specifically embedded payment processing from a third party (payment acquirers).
- « Previous
- Next »
