Broadband Renewal
mobymatt
Broadband Renewal
Hi folks.
I had an email to say my contract is coming to an end and to click to see what renewal options I have. When I do this, I get this response on my account...
'Please wait until we’ve finished updating your broadband service before making another change.'
Any ideas?
Thanks in advance for your help.
5 REPLIES 5
Fixes: 117
Re: Broadband Renewal
@mobymatt
This looks like the account glitch that's plagues PN accounts for a long time - the account doesn't update correctly after a change.
You can either wait for a staff member to come along and organize the fix or you could phone the PlusNet Customer Options Team on 0800 013 2632 to get it fixed and hear what's available to you.
mobymatt
Thanks for the info and advice, Brian. I will hold on and then give the number a call later in the week if I need to.
Matthew
outcast
Aspiring Champion
Fixes: 19
@mobymatt  if you still use a landline phone, then use this opportunity (of a new contract) to change your Plusnet connection to broadband only, and then migrate your landline phone number to a third party VoIP supplier - to allow you to continue using your house phone beyond the end of 2025.
LexLex2020
Fixes: 12
@mobymatt Hi!
It's just a request we will fill on our end to remove the in-progress banner on the account.
Just done this for you so you can make any changes you need, should see that complete within the next 24 hours.
Give it a try tomorrow after 1:30ish and see if it allows you to look at the contract options.
Hope this helps!
Kind regards, Lex
Lex Keehner
mobymatt
Hi Lex.
Just gave it a try and it's now fixed. Thank you.
Matthew
