An error has occured...
Grey2893
I've had the message "An error has occured.  You cannot make any changes to your account while there is a phone order in progress" on my account for a few months.  I phoned customer services on August 20th, but i'm still getting the error.
Could someone take a look for me?
Many thanks!
3 REPLIES 3
toothfairy
Re: An error has occured...
I have this exact same problem,posted in the forum and on Twitter with no reply to either,hope you have better luck !
adamwalker
Fixes: 223
Hi @Grey2893, I've just had a look over your account and could see what was causing the issue straight away so I've raised a task to our billing team to get that fixed and it should be sorted within the next day or two.
I'm really sorry we didn't do the right thing when you called to raise that with us initially so I'll be passing on some feedback about that.
Hi @toothfairy, I'm sorry it took so long to get your account sorted for the same issue, I've just checked it now and can see it's since been resolved but please do get back in touch if there's anything else I can help with.
 Adam Walker
adamwalker
Fixes: 223
@Grey2893 I'm just letting you know that I've had a confirmation that the issue has been fixed so you can go ahead and make any changes you need to.
 Adam Walker
