Adding usage to current month?
- My Account/Billing
- Adding usage to current month?
12-12-2010 11:20 AM
Hi, i want to add some gigabytes to my current months usage. I can't seem to find where this is done. I see this https://portal.plus.net/data_transfer_watch/ , but it says don't change till end of month.
Any help please?
Any help please?
Message 1 of 3
(841 Views)
2 REPLIES 2
Re: Adding usage to current month?
12-12-2010 12:22 PM
That's the correct place to make the change.
The message does seem odd but what I think it means is not to set the value smaller than you have already used for the current month. Waiting until the next month starts will avoid problems doing that will cause.
However in your case I think you are safe to increase the setting to what you need.
David
Message 2 of 3
(338 Views)
12-12-2010 12:38 PM
Cool. Thank you!
Message 3 of 3
(338 Views)
