sky way better
FIXED- Subscribe to RSS Feed
- Mobile
- sky way better
29-12-2016 9:31 PM
i have move to plus net mobile which they not good i move to sky mobile great deal & you will get more.
Fixed! Go to the fix.
Re: sky way better
29-12-2016 10:03 PM
So more expensive and you have to deal with sky who treat existing customers with no loyalty.
Re: sky way better
29-12-2016 10:15 PM
They also run on O2s network so no thanks...
Re: sky way better
on
30-12-2016
9:47 AM
- last edited on
31-12-2016
1:57 PM
by
Mav
That depends on your location, if the deals were closer than I'd take the Sky option as I'm a Sky customer although the 12 month contract would rankle a bit.
As it is £5 for 1GB/500 texts/250 minutes suits me fine and beats 1GB/unlimited texts & minutes for £10 any day of the week. I may jump up to the £7.50 2GB/unlimited texts/ 1000 minutes deal in the next couple of days anyway and still save with double the data.
If any mods are around can I upgrade via a PM or do I need to phone in?
Moderator's note by Dick (Strat): Full quote of preceding post removed as per Forum rules
Moderator's note by Mike (Mav): Insult removed as per Forum rules.
Re: sky way better
30-12-2016 11:47 AM
Good morning!
If you'd like to migrate from one of our SIM-Only Tariffs to another, you can do that freely and the change would then take effect on the next monthly bundle refresh date. Just as a heads-up, you can only switch to Tariffs that are available at that time - so, you might not always be able to switch back if you migrate away, which is something to bear in mind.
You can start a tariff migration by contacting us through the Live Chat at https://www.plus.net/mobile/, by email to mobile-help@plus.net, or of course by calling our Customer Service line on 0800 0791133.
Colin, I'll send you a PM about your Tariff.
Season's greetings!
Re: sky way better
30-12-2016 1:18 PM
Thanks for that Marc, didn't know we had email even. I'll reply to your PM shortly.
Re: sky way better
30-12-2016 2:58 PM
Best of luck with Sky! However it might be that the 02 Network is better in your area of course. I am very happy with the Plusnet deal - amazing value and no problems at all porting my number from GG and the coverage is better than I expected.
Re: sky way better
31-12-2016 8:44 AM
It's always difficult to know what the coverage will be like until you've tried it. EE lists as being the the same as O2 on the coverage checker (even the live one) where I am but there's a huge difference in signal strength. O2 comes up with all bars on the display but EE is only 1 bar indoors. However even with that there's no problem with reception - suck it and see is the only way.
Re: sky way better
31-12-2016 11:15 AM
31-12-2016 1:00 PM
A free (50p without any credit payment) Asda Mobile SIM will enable you to check 2G and 3G as it also uses the EE Network.
