mobile data on Sony k770i
- Mobile
- mobile data on Sony k770i
16-04-2021 6:43 PM - edited 16-04-2021 7:00 PM
I recently decided I wanted to use a old Sony k770i to try and stop myself from using my poco x3 nfc too often. I put my sim in and turned it on and fired up opera and it refused to connect! can someone tell me the settings I need to use?
Re: mobile data on Sony k770i
16-04-2021 7:58 PM
Moderators Note
This topic has been moved from Tech Help to Mobile
16-04-2021 8:04 PM
17-04-2021 11:30 AM
Hello @JezzDaBezz
I can confirm that @dvorak is correct, you can fine the settings here: https://www.plus.net/help/mobile/mobile-phone-and-voicemail-settings/#what-are-the-apn-settings-for-...
Please get back in touch if you need any further assistance.
