World charges
nickhope1
World charges
Hi , at the end of the month I am travelling to the Maldives. Please can you confirm …
1) if I Am on Wifi on the resort am I right I thinking that text messages , WhatsApp , FaceTime etc will be free ? Also are voice calls free over Wifi ?
2) if I am not onWifi please advise what the charges will be for voice calls and text messages ?
Thank you
3 REPLIES 3
Fixes: 339
Re: World charges
The rates when roaming can be found here https://www.plus.net/help/mobile/roaming-and-international-calls/
Whatsapp will work over wifi but normal SMS messages and voice calls will not and would therefore be charged
darcikuntz
Re: World charges
Thanks for this - much appreciated!
Alex
Fixes: 13
Re: World charges
I guess it depends whether the texts are delivered over the internet or a standard SMS? I know the iPhone can be temperamental on what it decides.
Also it may be worth looking at setting up some account over the internet, so if you have a working WiFi connection you can call people for free? I don't use VOIP, so I am not the best person to advise, but I assume you can do that.
Other thing I could suggest is getting your phone unlocked (if it is locked) and using a local PAYG SIM. That's what I did when I went to Australia and it worked out a lot cheaper. Main problem with that is people will have to contact you on a different number and pay for an international call.
