Signal
- Mobile
- Signal
Signal
11-05-2020 3:01 PM
Hello,
I've had no signal at home on my PlusNet mobile for a couple of days now, is there anything I can do to get signal back?
Re: Signal
11-05-2020 5:34 PM
Re: Signal
12-05-2020 2:19 PM
Re: Signal
12-05-2020 2:20 PM
Plusnet Mobile runs on the EE network.
Customer and Forum Moderator. Windows 10 Firefox 84.0.2 (64-bit)
Re: Signal
12-05-2020 2:30 PM
We do have a coverage checker that will show you what coverage to expect with us specifically, but @Strat is correct in saying we run on the EE network and any outages or maintenance will show on their network checker.
Re: Signal
13-05-2020 4:03 PM
Just for future Information if you go to the EE support pages and given them your PlusNet number EE will keep you posted on the phone mast you report via Post Code to check for service.
I did this last year when my local mast went off air and just the week before last it went off again and I had an SMS from EE telling me of the problem then another SMS hours later saying they can’t fixed the problem remotly and an engineer needs to go to site to fix it. Next day had another SMS saying it had been fixed and sure enough it had.
Never had anything like that from other providers with them being up front with the problem though the Three network uses the same cell but don’t send text’s of the problem but they do sometimes flag up any problem on there support pages.
