Nuisance calls
FIXED- Subscribe to RSS Feed
- Mobile
- Nuisance calls
04-09-2017 5:50 PM
can anyone tell me how i can block numbers on my plusnet mobile sim card
thanks for any help
Fixed! Go to the fix.
Re: Nuisance calls
04-09-2017 6:00 PM
There's usually an option already installed but you have to choose it for every nuisance number. I use Mr Number on Android (available on iOS I think) which auto blocks anything on its extensive list and is easy to add to.
https://play.google.com/store/apps/details?id=com.mrnumber.blocker&hl=en_GB
Re: Nuisance calls
04-09-2017 6:17 PM
I haveny got a smartphone, just an ordinairytalk and text one
Re: Nuisance calls
04-09-2017 7:16 PM
In that case look for your call log, you should have an option to block although it may be dependant on your handset. Do you know the make & model number?
05-09-2017 10:26 AM
Yes its called a Samsung E1205 ,its old so i may not be able to do anything withj it
Re: Nuisance calls
05-09-2017 11:30 AM
It looks like you're snookered on that one, I found a Vodafone page for the E1200 and it appears you can only blanket bar all incoming calls which would have the desired effect but the downsides could be a problem
Re: Nuisance calls
05-09-2017 3:27 PM
well thanks for all your help Colin, you have been fast answering my question, very efficient
