No signal in SN7
Karenmr
No signal in SN7
The past 3 days ive had no signal SN7 - any idea when this will be repaired and if I will be compensated?
1 REPLY 1
Fixes: 1,577
Re: No signal in SN7
I'm really sorry for the signal issues and apologies for the delayed response.
We normally wouldn't compensate for a major service problem as they're generally due to beyond our reasonable control.
You'll however be able to check if there's a known problem in your area by going Here.
Is all okay or do you still need help?
