Mobile service will not change !
- Mobile
- Mobile service will not change !
Re: Mobile service will not change !
13-04-2023 4:48 PM
13-04-2023 6:47 PM
Before last week's change I was able to make ip protocol 4 connections to my Plusnet home broadband, now I cannot.
The only change was the move from 213.x.x.x to 31.x.x.x so I, rightly or wrongly assumed the change was responsible for the failure.
Regards..
13-04-2023 6:49 PM
I'm now totally confused - think i'll leave this to @pjmarsh
13-04-2023 8:17 PM
I think we need more info on what it is you have setup and what isn’t working with it.
14-04-2023 10:50 AM
PJ,
| So it’s only connecting to you own network you can’t do via your mobile connection?
No, I cannot connect to any other networks.
This link shows what previously worked and what doesn't work now.
< https://www.iana.org/assignments/protocol-numbers/protocol-numbers.xhtml >
The protocol in question is number 4.
I guess I have wrongly assumed ( again ! ) that someone at Plusnet could answer my question, after all, the heading on this forum includes the word " technical " hence the inclusion of the protocol that has ceased to work.
Regards..
14-04-2023 10:58 AM
@C1Rider, it was you who said "I was able to make ip protocol 4 connections to my Plusnet home broadband, now I cannot".
It is working for me on that IP Range on two different SIM cards, and no one else is complaining about this, so is likely to be down to your device or SIM card
No one from Plusnet has commented on your thread on this Community form
14-04-2023 11:11 AM
PJ,
You are 100% correct quoting from a previous post of mine.
There has been two Plusnet staff responses to my question that I have replied to and nothing further.
Maybe I've been with Plusnet too long and it's time to move on when I can't get a straight answer to a simple question.
Regards..
14-04-2023 11:45 AM
You probably would get a straight answer to a simple question, but so far you haven't asked one. You seem to have made some incorrect assumptions and used some non-standard terminology that no-one else knows about. After over 20 messages on this thread I suspect I know what issue you are reporting, and if so someone may be able to help you.
Is your problem that data has stopped working on your SIM, though calls and sms still work?
14-04-2023 3:20 PM
PJ,
Please enlighten me, the problem you mention just happened on another of my phones.
Regards..
14-04-2023 3:28 PM
What problem that I mentioned? That data isn't working on your SIM, but calls and sms are? The first thing I'd check is that you haven't exceeded your allowance (or that any additional usage hasn't caused your smart cap to be hit). The next thing to check if that is all ok would be the APN Settings are correct
14-04-2023 3:34 PM
PJ,
Not exceeded allowance
Not reach smart cap
APN settings correct for Android phone
Regards..
14-04-2023 3:37 PM
I'd suggest calling Plusnet then.
14-04-2023 5:11 PM
I've read through this thread a couple of times I would say it is not clear to me what your issue is. Parking IP 4 Protocol for now, My Android phone can use two methods to connect to the internet
'Mobile Data' this would require the necessary permissions and availability of my chosen to work, which is Vodafone. The sim card holds the key for this service.
'WiFi' this uses a local wireless network which may or no be secure.
A mobile does not need a sim card for the WiFi connection to work, there will be no access to mobile phone calls and texting.
So for clarity which are you having an issue with Mobile Data or WiFi and which applications?
14-04-2023 7:53 PM
Dan_the_Van,
" Parking IP 4 Protocol for now, My Android phone can use two methods to connect to the internet "
My phone(s) are functioning the same as you describe above ; its ip protocol 4 that is not.
I think this has been done to death as it appears I am the only one who understands what has changed and that was evidenced this afternoon when another of my phones was changed from 213 network to 31 network resulting in the loss of data and my dual sim phone pinging me that my data sim had no connection, did I want to use my other sim ?.
I appreciate the suggestions/help from other users and in posing my original question I was questioning why I do not have the same functionality now as I had up until the change as the info from Plusnet regarding existing SIM card users told me that there would be no change.
Maybe it was a coincidence, maybe not, maybe Plusnet are moving all mobile users away from 213 network, maybe it is a security issue, who knows ?
Certainly not me.
Regards..
14-04-2023 8:14 PM
- Mobile
