Mobile Broadband
- Mobile
- Mobile Broadband
Mobile Broadband
14-07-2023 4:22 PM
Do Plusnet do a mobile broadband package?
Currently on FTTP with Vodafone and looking for a replacement due to poor speeds.
Keef- Sheerness Kent UK - Vodafone FTTP via THG3000 & Three via ZTE MF286D
Previously - NowTV, John Lewis, Shell Energy, Plusnet, Sky, EE, New Call Telecom/Fuelbroadband, Virgin/NTL/Bell Cable, Crosswinds, IC24, FreeOnlineNet, X-Stream, Totalise, Freeserve, Force9, TescoNet, AOL, Freenetname, Pipex, E7
Re: Mobile Broadband
14-07-2023 4:35 PM
14-07-2023 4:42 PM
![](/skins/images/9F14AD90732801550160C88EF1B389FA/responsive_peak/images/icon_anonymous_message.png)
14-07-2023 5:10 PM
What are you trying to achieve ?
Are you looking for a data plan to use on a portable computing device, such as a laptop, tablet, or phone - each with the possibility of creating a WiFi hotspot.
Or are you looking for wireless alternatives to provide broadband for your home ?
I'm asking because "mobile broadband" and "wireless broadband" are different things, depending on what you're trying to do.
14-07-2023 6:57 PM
@Anonymous Because of poor speeds on Vodafone FTTP the Op wants to switch to a mobile broadband service.😫
see this thread .... https://community.plus.net/t5/Broadband/ADSL-offers/m-p/1929410#M358674
14-07-2023 7:18 PM
Yes I realise that, my point was whether @cbcadmin really meant "mobile broadband" (because perhaps that is all they think exists), when there are perfectly good "wireless broadband" providers that DON'T use the mobile 3G/4G/5G networks to provide fixed wireless broadband.
See https://www.ispreview.co.uk/broadband_wireless.php
and https://www.ispreview.co.uk/isp_list/ISP_List_Wireless.php
14-07-2023 7:40 PM
Given that @cbcadmin 's signature says they are in Sheerness Kent
These are the wireless broadband providers with coverage in Kent -
It would be worth @cbcadmin going to each provider's website and checking the wireless coverage at their home postcode.
https://shop.b4rk.co.uk/pages/checker
https://bitstreme.io/broadband
15-07-2023 1:44 AM
15-07-2023 1:51 AM
15-07-2023 1:56 AM
15-07-2023 2:12 AM
15-07-2023 2:24 AM
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
15-07-2023 9:56 AM
![Sad Sad](/html/@5863905B9AC6EE4F2B28C1A2965ABC0C/images/emoticons/sad.gif)
16-07-2023 10:26 AM
@cbcadmin wrote:
.... ... Three are sending me a SIM so I can test it before I commit to a contract. If nothing else it will be a good backup.
While you are in the process of exploring every possibility, you might as well check which mobile network gives you the very best INDOOR mobile DATA coverage at your address, although from what I can see that appears to be 4G only - as 5G doesn't appear to have reached Sheerness yet.
If you visit the Ofcom : Mobile broadband coverage checker
- Enter your postcode, and hit the <Set postcode> button
- Then select your exact address from the dropdown "Select your address" list
- Click on the <View map of available services> button, which then shows a coverage map at your address.
- Now click on the <Indoor> button - to ensure you are seeing predicted indoor coverage
- Click on <Data> button (so that you are not viewing voice coverage which includes 2G)
- Then in turn, click on each of the four network providers (Vodafone, O2, EE, Three), and see which gives you the best signal for your address and immediate surrounding area.
- For each network, check whether the <5G Data> button becomes active, in case you can get 5G at your address - although that might be irrelevant now that you've paid for a "ZTE MF286D" 4G router..
Given that 'Three' that you've mentioned seems to have slightly less coverage than the other networks in Sheerness, you might as well get trial SIMs from 'O2' and 'Vodafone' (that both have better coverage) to see whether they give a better signal strength when used in your eBay "ZTE MF286D" 4G router.
16-07-2023 12:42 PM
Thanks.
https://thumbsnap.com/diPgTnra
I am aware 3 don’t have 5G in Sheerness yet, but understand 4G should give me reasonable speeds and true unlimited data.
