Login
- Mobile
- Login
Login
02-08-2017 9:34 AM
For few weeks I have been trying to login to check my allowance, and every time I get failure message and I have to reset the password
I wonder what is going wrong please!
dar781111
Message 1 of 2
(457 Views)
1 REPLY 1
Re: Login
02-08-2017 11:34 AM
Hi dar781111! I'm sorry to hear that you're having problems accessing your online My Account!
Your online My Account password is case sensitive, so make sure you're typing it in exactly to what you have changed it to! Also, be aware that password reset links only have a 24 hour time limit to be used!
If you're still experiencing problems, drop me a PM, and i'll be sure to follow this up with you -Sean
Message 2 of 2
(422 Views)
