Is there a place to order two SIM cards?
Ado16
Hi!
I'd like to order two SIM cards, I've started to got through the signing up procedure (which is odd in itself as already a Plusnet member, but I guess there are legal requirements.) - but how can I order two SIM Cards for family at the same time?
Thanks.
2 REPLIES 2
RebekaPreston
Fixes: 31
Re: Is there a place to order two SIM cards?
Hi Ado16,
Thank's for getting in touch. You can either contact our Sales Team on 0800 328 4677 and they'll be able to order you multiple SIM cards or you can order online. If you order online, you have to order them separately, there is no drop down for multiple SIM cards. Order one and when that has gone through, you can go back and order another one, you'll receive a separate confirmation email for each one and both will have two separate order numbers.
If you order online and are unsure if they have gone through, send me a private message with the order numbers for both SIM cards and I can check these for you.
Hope this helps!
- Rebeka Smiley
 Rebeka Preston
Ado16
Thank you for that! Will get on to it - before time runs out! Wink
