Is Plusnet Mobile any good?
- Mobile
- Is Plusnet Mobile any good?
03-09-2020 12:09 PM
They’re offering a good deal online, £8 a month for 3.5Gb of data and they let you tether for free too. Tired of the [-Censored-]e signal on three mobile. Think Plusnet uses EE. Anyone got any experience with them? Cheers
Re: Is Plusnet Mobile any good?
03-09-2020 12:24 PM
I have just switched to Plusnet mobile and fear that I have made a terrible mistake by going for „best price“. Not only do they activate your SIM card before zip have even received it they send you a SIM card that does not fit your phone. As I ported my old number (which they also did before I received my Sim) I am unable to phone them to complain as I can no longer use the Sim from my old provider, live by myself and have no landline phone. I have now emailed them, only to receive a reply telling me that someone should contact me within 24 hours... just hope that they are not attempting to do so by phone!
Having looked though the topics on here it seems that they also charge you to send out the correct Sim...what great customer service NOT,
03-09-2020 2:05 PM - edited 03-09-2020 2:07 PM
The sim thats sent out is a multi sim. It's a standard size sim card with press outs for nano and micro size sims.
03-09-2020 2:13 PM
You're right, PlusNet is a virtual provider using EE. Just remember that "using EE" does not equate to "is the same as EE".
The most notable difference is a lack of 4G-voice-calling which restricts access to the 800Mhz coverage band. This can make a difference to signal indoors and in rural areas where it's available.
03-09-2020 2:16 PM
Thanks Mr W ... I could see the outline of the Stamdard and Micro Sims but not the Nano SIM... have now managed to fit it...
03-09-2020 2:19 PM
Quite so, which is why there's a separate coverage checker to EE's for Plusnet.
https://www.plus.net/mobile/coverage-checker
FTTC 40/10 Billion 8800NL
BT technician (Retired)
03-09-2020 4:20 PM
No problem, happy to have been of help
