Data tethering not working on Ulefone
- Mobile
- Data tethering not working on Ulefone
17-10-2017 1:11 PM
I have a Ulefone Metal (Chinese, but better performance than many A-level phones), but I can't seem to get the tethering working with Plus Net.
Does anybody know of a fix for this, so I can use my tablet with the Plusnet data?
Re: Data tethering not working on Ulefone
17-10-2017 2:18 PM
Hi AJvan!
Thanks for getting in touch!
We do support data tethering however, this is handset dependant and only if the handset allows. I can't advise of the make and model specifically however, due to it's origin and specifications, this may be the reason as to why it isn't working.
I would advise to speak with the handset manufacturers themselves regarding this.
- Rebeka
17-10-2017 2:48 PM
@AJvan you'll probably need to do the 'tether dun required' trick. See here https://diggle.tech/news/2016/03/enable-tethering-android-5-1-beyond-marshmallow/
16-11-2017 6:47 PM
Tried#4, without computer, but no luck, will try the other USB options this weekend and report back here.
16-11-2017 7:26 PM - edited 16-11-2017 7:26 PM
@AJvan yes, I tried that first on my Cubot phone. I had to do the 'tether_dun_required' setting using adb
04-12-2017 7:53 PM
Thanks a lot!
- Mobile
