Can't use phone in Bulgaria
Kosat
I'm unable to use my mobile in Bulgaria, calling Plusnet customer service was a complete waste of time.
Is there a technical support phone number?
I see on here someone else had the same problem but don't know what they did to fix.
Any help appreciated
KO
8 REPLIES 8
MasterOfReality
Fixes: 57
Re: Can't use phone in Bulgaria
Hi @Kosat
I'm really sorry to hear this is the case.
In Bulgaria, we have agreements with the following carriers;
Telenor Bulgaria
MobiTel AD Bulgaria
are you connected to either of these carriers? If not, please can you try manually connecting your phone to one of these?
When you say you are unable to use your phone, is this specific services, or are you unable to gain a connection to a carrier whatsoever?
Thanks,
MoR
 MoR
Kosat
I have tried 4 different networks,
Viacom allows me to use the internet but no text.
Telenor won't allow me anything
1 other network allowed me to make a call but I can only find it now and again.
Seems to default to vivacom.
Cheers
KO
Kosat
Sorry my message isn't clear .
Vivacom no voice calls either, but when I try ring I get a message in Bulgarian then English saying " outbound calls are blocked"
MasterOfReality
Fixes: 57
Hi @Kosat
That's very strange as we don't seem to have an agreement with Vivacom.
I'd like to look into this for you.
I'll just need to pass some Security with yourself and then we can look into your query.
Could you please PM us with the following details;
-  your full name
-  your full address including postcode
-  your mobile number
Kind Regards,
 - Alisdair
 MoR
Kosat
Hi, did you have any luck?
KO
MasterOfReality
Fixes: 57
Hi @Kosat
I've been waiting for a reply and just got it a few minutes before you posted again.
There is nothing at an account level which we can point to and state its the cause of your issues - there is nothing blocked as and your international access is turned on.
Can you try your SIM in a n alternate handset for us (i know this seems like a stupid thing to request, but our Operations Team will ask you to do this if we end us progressing this to their level, so its better to try it now).
Thanks,
MoR
 MoR
Kosat
Well I eventually sorted my problem myself as no one on here had any positive help and certainly Plusnet customer care absolutely don't care. We will do you proud....what a false statement!!
Easy solution for the next ignored person with a similar problem.
CHANGE SUPPLIER!!
That's me finished with Plusnet..
Mads
Fixes: 79
Hi there @Kosat,
I am sorry to hear this was the outcome of the issue you were experiencing and I apologise for the inconvenience caused.
We wish you the best of luck with your new provider. Please do let us know if there is anything else we can assist you with.
 Maddy S
