How do I stop mobile data be used?
pnPhorum
It might seem a stupid question, but it is not.
We have a £. 6/m simple contract,but how do I have mobile data BLOCKED at PlusNet [rather than phone] as we do not use it and only use Wi-Fi if ever?
Phone is oldish, therefore certain Data Block apps do not work any more as phone OS has stopped at 4.4.4v !
Cannot do more than it is doing, I cannot even take Google Search off the screen - that too does not work!
It is the wife's phone and only does tests and phone calls, never internet.
Thank you, please be nice.
;p]
M
6 REPLIES 6
DS
Seasoned Champion
Fixes: 22
Re: How do I stop mobile data be used?
As you've mentioned 4.4.4, I assume it's an android phone?
Normally, menu - settings - mobile data (maybe just data) and tick/swipe from yes to no
This turns off the mobile data part, but allows calls and texts.
pnPhorum
Hi
As mentioned it is old and yes, mobile data is off.
I need to clear it with PlusNet first as their website is a bit on the 'do not know what is going on' side.
We will see.
I am already looking on another phone, but with limited choice.
;p[
SammyM
Fixes: 91
Hello @pnPhorum,
Thanks for getting in touch and welcome to the forum. We would be happy to check your package and what options we have available to assist with your request.
Please can you PM me the following;
-Mobile number in question
-Full name
-Address including postcode.
Once we have this , we will be able to assist further.
 Sammy M - Sheffield Team
pnPhorum
Sorry for late reply - busy.
We solved it via phone, it was a delayed D/D by PlusNet [or BT !]
Regards
M
pnPhorum
Sorry, should have mentioned it - android.
Anyway best bet is when I can afford to upgrade my phone, I will give mine to wife - at least this one is on Android 7 and no problems at all!
The old phone is actually OK and was not a mobile data leak after all - I thought so the lock still works - I also have an app that still works on android 4.
The only thing I cannot do is get rid of Google search on the screen!
It cannot be done with this phone, I gathered - I tried various methods.
One of those things.
Time to upgrade, but not just yet!
M
Fixes: 1,596
Ah fair, no problem.
Feel free to let us know if you need any further assistance.
