Apple watch
- Mobile
- Apple watch
Apple watch
12-03-2022 4:18 PM
Ive had a bad fall and want to buy apple watch with fall detection can i pair it to my iphone with plusnet mobile or will i have to move mobile providers
Message 1 of 2
(1,421 Views)
1 REPLY 1
Re: Apple watch
12-03-2022 4:39 PM
Pairing with your iPhone isn't dependant on your mobile operator.
However, you PN doesn't support cellular Apple Watches.
Unless you plan to leave your iPhone at home a lot and just go out with your watch then the cellular one is overkill.
You can still answer calls etc. on your watch - it just needs to be in range of your iPhone.
Family have iPhones and apple watches using PN just fine.
Message 2 of 2
(1,409 Views)
