Bolt on validity
spraxyt
Resting Legend
Fixes: 75
Bolt on validity
iOS app. My monthly allowance reset today as expected. However if I go to bolt ons and select any of them, the message at the top says whatever I choose will expire on 10 September, which is yesterday.
David
5 REPLIES 5
JonoH
Fixes: 157
Re: Bolt on validity
Hi Spraxt, can you attach a screenshot and PM it me please?
 Jono H
 Plusnet Community Manager
spraxyt
Resting Legend
Fixes: 75
@JonoH
Shots of the Home screen showing the correct "next reset date" and the Data bolt on screen showing the just expired period for "validity" are attached here.
David
JonoH
Fixes: 157
Thanks for sharing!
 Jono H
spraxyt
Resting Legend
Fixes: 75
@JonoH Now that my Mobile billing date has been reached the "Choose a Bolt-on" will last until date has changed to the correct value of October 10th 2018.
As I suspected the change over is being triggered by billing date whereas I think it should be the allowance reset date.
David
JonoH
Fixes: 157
This has now been raised as a new bug. Thanks for pointing it out.
 Jono H
