ipv6 sites
brueton
7 REPLIES 7
avatastic
Re: ipv6 sites
There is also a list at http://isoc.org/wp/worldipv6day/ipv6-enabled-websites/ ; Smiley
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
MrToast
Re: ipv6 sites
Also http://ipv6.bbc.co.uk It seems to include iPlayer too.
AxeMurderer
Re: ipv6 sites
Can anyone add some sites that definitely don't work with IPv6? They will be handy when I get around to my own personal IPv6 day.
brueton
Re: ipv6 sites
If you mean sites that don't work with ipv6 enabled and ipv4 disabled then the vast majority fall into this category, see my earlier post http://community.plus.net/forum/index.php/topic,96183.0.html.
If you mean sites that fail when you have both ipv4 & ipv6 enabled then I have not come across any yet.
Pete
MrToast
Re: ipv6 sites
HE run a daily progress report for IPV6 deployment:
http://bgp.he.net/ipv6-progress-report.cgi
brueton
Re: ipv6 sites
It looks as if the BBC is taking part in ipv6 day.
nslookup www.bbc.co.uk
Server:  ordns.he.net
Address:  2001:470:20::2
Non-authoritative answer:
Addresses:  2001:4b10:bbc::1
          212.58.244.66
Aliases:  www.bbc.co.uk
brueton
Re: ipv6 sites
