TBB graph latency increase on IPv6
brueton
Did anybody else see the latency increase between approx. 9pm & 10pm last night (Tue 28 Jan 2014).
It appears to be on IPv6 only.
Router is Billion 7800N.
34 REPLIES 34
jelv
Fixes: 10
Re: TBB graph latency increase on IPv6
Never mind the latency - what about that packet loss all day!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
brueton
Kelly
Fixes: 9
Any other IPv6 customers see a similar hump on their graphs?
Kelly Dorset
Ex-Plusnet Jobsbody
jelv
Fixes: 10
No - not to the same extent - but my connection was practically idle between 7pm and 10 pm.
brueton
Not just last night, seems to happen most nights, some are worse than others.
19 Jan 2014
18 Jan 2014
07 Jan 2014
06 Jan 2014
jelv
Fixes: 10
What on earth is it with the packet loss on your connection? That's so bad you ought to be raising a fault (unless it's something you are doing).
brueton
I have raised a fault, ticket 79943732. Waiting for an update which I fear is going to be arranging for an engineer to visit my house when the problem is most likely at the exchange.
Most recent update was on Monday 27 Jan
I am sorry to see that you are experiencing a speed fault.
I have raised this issue with our suppliers.
They have a standard lead time of 48-72 hours to provide a response however we will check for updates sooner and contact you as soon as one is available.
I apologise for any inconvenience caused.
It is not just my connection, a neighbour a couple of doors along, also with Plusnet, is getting the same packet loss.
28 Jan 2014
jelv
Fixes: 10
Do you know anyone using an ISP other than Plusnet (but not LLU) on your exchange? If so are they seeing the same issue?
brueton
Have not found anybody else. Everyone I have asked is either Sky, Talktalk or VM cable.
jelv
Fixes: 10
No BT users? I bet if you look at the wireless networks available there's going to be a homehub near you showing up!
brueton
One of the "downsides" of living at the end of the lane in a semi-rural area. Not many wireless networks or neighbours.
Just having a look now and can see one VM and three Sky wireless networks.
Probably best if any further discussion on the packet loss is in the topic I opened for that purpose. http://community.plus.net/forum/index.php/topic,122504.0.html
I opened this topic to highlight the difference in latency between IPv4 and IPv6 I am observing at certain times of day. I guess that if there is an exchange fault it might be the cause of both the packet loss &  difference in latency.
If one of the mods sees this Would it be possible to move the packet loss discussion to the other thread?
AndyH
I had the same "bump" - some light web browsing during most of that time:
brueton
@AndyH
Did you see a hump on other nights?
7 Jan 2014 seemed to be quite bad for me. There was no use at all of my connection that day, house was not occupied.
brueton
