Raising IP profile for IPv6 test account
MJN
Seasoned Pro
Fixes: 5
Hi PN,
I was upgraded to a FTTC connection yesterday and whilst the profile of main account has been raised to 40Mbps this is not the case with my IPv6 account (ipv6test15). Could I get you to do whatever is necessary to raise it from the current 7.4Mbps?
Mathew
8 REPLIES 8
bobpullen
Fixes: 330
Re: Raising IP profile for IPv6 test account
Should be sorted now Mathew.
MJN
Seasoned Pro
Fixes: 5
Thanks Bob.
Is it significant that the line speed is listed as 37Mb whereas that for my 'mjnewton' account is listed as 40Mb? I'm not connected to the IPv6 account at the moment (will do so after work) so perhaps that's relevent?
bobpullen
Fixes: 330
I set the profile to 40Mbps at this side, so you shouldn't have any problems. Shout up if you do.
MJN
Seasoned Pro
Fixes: 5
Thanks Bob - it all seems to be working fine.
jelv
Fixes: 10
I'm due to upgrade on 14th - will there be any point ringing in to ask for the IPv6 account to be updated or do I need to post on here on once it's up and running?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
bobpullen
Fixes: 330
Probably best to post here jelv. I'm subscribed to this topic anyway so should be able to sort it out for you.
jelv
Fixes: 10
Could you set ipv6test10 current line speed to 40 please.
Test using own account:
bobpullen
Fixes: 330
Done.
