Netgear DGND4000
- Trials
- IPv6 Trial
- Netgear DGND4000
Netgear DGND4000
15-04-2014 6:27 PM
Got the IPv6 account configured as my internet login and it assigns me an ipv4 address and works all fine
When I go to the IPv6 settings and select auto detect I get 6to4 tunnel as the detected connection type.
If I select ppoe and enter my ipv6 details, hit apply, nothing seems to happen, it just seems to stay connected to IPv4 and I get
Quote Router's IPv6 Address On WAN
Not Available
I noticed a couple of netgear threads with similar issue but no final answer, has anyone been able to get it working? I need to pop out but when I get home I'll have another play with it!
Re: Netgear DGND4000
15-04-2014 6:59 PM
15-04-2014 7:02 PM
Auto config
6 to 4
Fixed
DHCP
PPPoE
Pass through
I've tried them all now to no avail. PPPoE doesn't seem to do anything which is odd! I'll keep googling!
15-04-2014 7:08 PM
Does it connect when you select PPPoE?
15-04-2014 7:09 PM
The trial is native IPv6 not a tunnel.
15-04-2014 8:05 PM
15-04-2014 8:42 PM
choose pppoe and then if an options for it pick dhcp-pd
15-04-2014 9:16 PM
15-04-2014 9:44 PM
15-04-2014 10:49 PM
