IPv6 when?
- Trials
- IPv6 Trial
- IPv6 when?
Re: IPv6 when?
08-02-2011 12:09 AM
Re: IPv6 when?
08-02-2011 12:20 AM
Surely any Windows machine would be infected in a matter of seconds if it weren’t for NAT?
BTW no-one needs uPnP (well I have it disabled in the router).
Re: IPv6 when?
08-02-2011 12:25 AM
Quote from: MrC But as Ben says - you don't need NAT. NAT was a fudge initially created to get around the old pre-CIDR restrictions and has caused a whole load of pain and complexity in a number of application protocols. There's no reason why UPnP can't work for inbound connections with IPv6 - it's actually a lot simpler without the NAT layer.
The conversation about double NAT was about interim IPv4 based solutions until IPv6 is universal.
Quote from: A BTW no-one needs uPnP (well I have it disabled in the router).
uPnP may for many be uneeded, but double NAT still breaks many things, I just used uPnP as an example because you mentioned it and its relatively easy to explain why double NAT breaks it.
Re: IPv6 when?
08-02-2011 9:51 AM
Quote from: A Surely any Windows machine would be infected in a matter of seconds if it weren’t for NAT?
Not really - the only time NAT gives any protection is to prevent inbound connections if you have no firewall on your router, or on devices behind your router. It does nothing for the most common of exploits which rely on people initiating connections from inside their networks, eg browsing to compromised web servers.
The firewall s/w in just about all modern routers will be set to prevent all inbound connections by default and, with that in place, it doesn't matter whether NAT is active or not. There's also the point that most modern OS's implement the same policy within their own firewall s/w. When/if local native IPv6 finally gets rolled out most older routers will likely need replacing (or have new firmware installed) so the likelihood of not having such a firewall policy in place is pretty small. The same also applies to older OS versions (eg XP pre-SP2) although they'll likely not have full support for IPv6, if at all.
Quote from: A BTW no-one needs UPnP (well I have it disabled in the router).
Quite, and FWIW I also have it disabled here. From a strict network security standpoint UPnP has the potential for something inside the local network to remove (either maliciously, or by bad design or misconfiguration) the protection provided by the router's firewall .
Playing devil's advocate though, a lot of application networking protocols require inbound connections for peering, and UPnP takes away the need for a user to need to know about the gory details of what these are, and how to configure their firewall and NAT s/w. Another advantage of UPnP is that (if it's working properly) it revokes the firewall/NAT rule changes when they're no longer required, whereas without UPnP it's likely the firewall will end up with a lot of inbound connection rules, some of which may no longer be in use.
At least with IPv6, manually changing the router gets a bit simpler as there's no NAT layer to worry about.
The next few years are going to be very interesting for ISPs and their customers as, unless they get together to coordinate their efforts, no 2 ISPs are likely to have the same migration policies. There's grounds for a lot of confusion and FUD coming up.
Re: IPv6 when?
08-02-2011 2:13 PM
I could be wrong, but most infections are caused by bots that scan IP addresses, they know for instance that PlusNet own 212.159.x.x so they can start to scan from 212.159.0.0 to 212.159.255.255 or whatever looking for vulnerable machines. My IPV6 address on my PC is 2001:470:1f09:611:24fb:8d3e:a871:6e77, and on my mobile the IPV6 address is 2001:470:1f09:611:3ef7:2aff:fef3:dld4, so scanning (and I'm probably very wrong here!) 2001:470:1f09:611 would give them *me* but then they would need to find the address of my computers which as you can see are not numerical, so while on IPV4 my PC may be 192.168.0.10 and my mobile 192.168.0.11 the scanning range needed to find vulnerabilities is HUGE and would require a super computer to figure out my IPV6 address to start scanning.
Of course, if I look at my IPV6 address on the internet, the reply comes as 2001:470:1f09:611:bd01:d59e:6d7:70a2 which is different again, hrm, Windows actually lists both addresses giving 70a2 a temporary IPV6 address, umm, I don't have any clue as to why that is, but yeah, scanning IPV6 addresses will take a lot longer than scanning for IPV4 addresses and Windows firewall should naturally block bad traffic anyhow (don't think XP does IPV6 by default so you'll be looking at Vista and 7 which do come with firewall enabled by default). Windows 7 and Vista are a lot more secure than XP ever could be so they wouldn't get infected just by connecting to the internet anyhow.
Re: IPv6 when?
08-02-2011 2:17 PM
Re: IPv6 when?
08-02-2011 3:06 PM
Re: IPv6 when?
08-02-2011 3:10 PM
Re: IPv6 when?
08-02-2011 3:11 PM
Yes, when using NAT you get the added benefit that its stateful so only allows incoming connection to existing outgoing traffic (or where youve configured PAT) however the downside is that its not possible to connect inbound to your machines from 'the internet'
Some may see this as an advantage, but it causes all sorts of problems with P2P, chat etc where end to end conectivity is required and this also allows for new technologies in the future where end to end is a must, ie, want to tell your lights/heating to turn on from work before coming home? Check what in the fridge? I dont fancy manually adding all the PAT details when EVERYTHING is connected
Any CPE does IPv6 will (probably) do NAT4 for your IPv4 conection and a stateful firewall (dewfault deny) for IPv6 which gives you exactly the same setup as NAT on v4.
Ben
Re: IPv6 when?
08-02-2011 3:26 PM
Quote from: fourfourdevon It has no effect on software firewalls.
Exactly what I thought. So I'm curious as to why there are security concerns about the removal of NAT.
Re: IPv6 when?
08-02-2011 4:15 PM
If you go http://www.whatismyipv6.net/?s=IPv6_ping <-- there, it'll ping your IPV6 endpoint which is a goodish indicator of if your firewall drops packets, in my case:
PING 2001:470:1f09:611:bd01:d59e:6d7:70a2(2001:470:1f09:611:bd01:d59e:6d7:70a2) 56 data bytes
--- 2001:470:1f09:611:bd01:d59e:6d7:70a2 ping statistics ---
2 packets transmitted, 0 received, 100% packet loss, time 1009ms
Which to me suggests my router is dropping the packet, shields up doesn't do IPV6 yet though for a complete test.
Re: IPv6 when?
08-02-2011 4:29 PM
Re: IPv6 when?
08-02-2011 4:47 PM
Re: IPv6 when?
08-02-2011 4:55 PM
F9 ADSL customer since 2004
F9 FTTP customer since 2024
Re: IPv6 when?
08-02-2011 9:07 PM
