IPv6 when?
- Trials
- IPv6 Trial
- IPv6 when?
Re: IPv6 when?
03-02-2011 1:45 PM
Re: IPv6 when?
03-02-2011 2:34 PM
3Mb FTTC
Re: IPv6 when?
03-02-2011 2:58 PM
Duplicate MAC addresses on other subnets won't as far as I can tell cause any problems.
So yes, MAC addresses are a finite resource and will run out sooner or later, although MAC addresses are 6 bytes, giving them 65536 times more addresses than IPv4 so I'm not sure there is a problem at all, or at least not one consumers need to be worried about just yet.
Re: IPv6 when?
03-02-2011 3:27 PM
Strangely, with IPv6, a standard LAN subnet of /64 actually has more available IP addresses than the total MAC address space! So you'll run out of available MACs before filling a /64 subnet!
Ben
Re: IPv6 when?
03-02-2011 3:46 PM
Re: IPv6 when?
03-02-2011 3:48 PM
Quote from: richandsian
Quote from: David As far as I'm aware, Netgear offer *no* IPV6 enabled routers.
I believe my DGND3300 does... unless Netgear were just taking the mickey when they left the configuration page in for it.
Quite right, I just checked. If you head over to www.tunnelbroker.net you can sign up and add the DNS to the 6to4 tunnel and get IPV6 now, although you'll need to notify the site every time you disconnect unless you have a static IP. Be interesting to know if your router firewall works with IPV6 traffic to, the Netgear site doesn't even mention IPV6 and (if I'm reading this right) the config page is actually hidden?
Out of interest, what CPE are you looking at PlusNet? Thompson, Netgear, Zyxel, Cisco, Billion?
jim:green link fixed mod:end
Re: IPv6 when?
03-02-2011 4:29 PM
Quote from: fourfourdevon I guess we can all run our own subnets then, one for each room in the house?
Thats the idea.
You *should* be assigned a /56* from your ISP, thats 256 x /64 so you get 256 subnets by default, each /64 is 18,446,744,073,709,551,616 hosts!
Is that enough for you? 😉
Ben
* upto a /48
Re: IPv6 when?
04-02-2011 12:03 PM
Quote from: benoh You *should* be assigned a /56* from your ISP
Thats what we've been testing
Re: IPv6 when?
04-02-2011 12:35 PM
FF:FF:FF:FF::/32 is my ISP, meaning there can be 4,294,967,296 ISP/Networks before we run out
FF:FF:FF:FF:FF:FF:FF::/56 is my network, meaning that each ISP can have 16,777,216 customers
FF:FF:FF:FF:FF:FF:FF:FF:/64 is my subnets, so I can 256 subnets - probably not enough for some large businesses
and the rest is my nodes in the subnet
Could I increase the number of subnets available to me by changing the mask? Or is it more rigidly defined than the current IPv4 model?
Re: IPv6 when?
04-02-2011 3:59 PM
Also, when are PN going to upgrade their websites to use IPV6? Currently www.plus.net and portal.plus.net resolve to only IPV4, will you be dual stacking them anytime soon?
Re: IPv6 when?
04-02-2011 5:39 PM
Quote from: _CN_
Cool, some ISPs seem to be trying to be cautious and allocating a smaller prefix.
I dont see your v6 prefix in the routing table atm, perhaps you could announce it and try to get onto ipv6ripeness.ripe.net by enabling some basic services, dns, mail, web?
Ben
Works at RIPE NCC hence hastling about v6 😉
Re: IPv6 when?
04-02-2011 5:46 PM
Quote from: fourfourdevon So, just working this out...
/32 is allocated to an LIR from the RIR, thats the minimum allocation size, with justification they can get whatever they need.
See http://ripe.net/info/info-services/addressing.html
Quote from: fourfourdevon FF:FF:FF:FF:FF:FF:FF::/56 is my network, meaning that each ISP can have 16,777,216 customers
/56 is given to 'end users' by an ISP, businesses should get a /48, for a site, and if they have multiple sites a /42. A /48 is 256 /56s or 64k /64s so plenty of subnets available, probably run out of VLAN IDs before subnets!
Quote from: fourfourdevon Could I increase the number of subnets available to me by changing the mask? Or is it more rigidly defined than the current IPv4 model?
using a /64 on a vlan allows stateless auto configuration to work, ie interfaces will assign their own unique address automatically and find the router by neighbour discovery....plug and play.
You can subnet all the way down to /127 for a point to point link if you wanted, but its not recommended.
I tend to think of a /64 being equivalent to /24 in IPv4 space, certainly for home users who usually use 192.168.1.0/24 for their internal network.
Ben
Re: IPv6 when?
04-02-2011 7:40 PM
Quote from: David
[Moderator's note by Jim (Oldjim) link fixed ]
You can also use freenet6, who give you a desktop client that logs in and gives you an ipv6. No need to let them know if you change IP. http://gogonet.gogo6.com/page/freenet6-ipv6-services
You can either log in with a username and get the same address (range) each time, or log in anonymously.
Re: IPv6 when?
04-02-2011 10:31 PM
Re: IPv6 when?
05-02-2011 12:50 PM
http://gogonet.gogo6.com/profiles/blogs/gogocpe-is-now-available
Ben
