IPv6 when?
- Trials
- IPv6 Trial
- Re: IPv6 when?
Re: IPv6 when?
08-02-2011 9:30 PM
Re: IPv6 when?
09-02-2011 10:49 AM
Re: IPv6 when?
09-02-2011 11:02 AM
Re: IPv6 when?
09-02-2011 12:32 PM
Quote from: avatastic XP Does support IPv6
With the important omission, which affects anyone using just a DSL modem, that it doesn't support ppp6. Another, slightly less important point, is no support for dhcp6. It could be that someone could provide these via an addon software package but it's something ISPs will have to consider if/when rolling out native ipv6 (ie without 4 to 6 gateways/proxies).
Re: IPv6 when?
09-02-2011 12:43 PM
Re: IPv6 when?
12-02-2011 9:52 PM
Quote from: _CN_ A blog will be posted in the coming weeks, this will include our plan etc.
Its understandable that much of the interest here is for IPv6 access for broadband connections. However, what about public facing web and email servers?
Anybody running a business will want to remain accessible to the whole world once IPv4 has run out. This point is approaching fast in the Asia-Pacific region.
Re: IPv6 when?
12-02-2011 11:30 PM
Even after addresses have run out there are many ways to stretch, reuse, dual use etc IP addresses.
I'm not suggesting anyone should rest on their laurels because of that, far from it, as things get stretched and reused more we will see cracks and errors arise, but what I do mean is, for general consumer there is no need to panic that in the near future some email or web services will become unavailable to you because Plusnet don't yet support IPv6.
Re: IPv6 when?
13-02-2011 12:00 AM
In some parts of the world IPv4 depletion means that new connections will be IPv6. If you run a B&B in Yorkshire you would not want to miss the growing Asian market.
Re: IPv6 when?
13-02-2011 12:37 AM
There is little danger of what you suggest.
Re: IPv6 when?
13-02-2011 2:26 PM
C:\Users\David>nslookup www.thinkbroadband.com
Server: cdns02.plus.net
Address: 212.159.6.10
Non-authoritative answer:
Addresses: 2a02:68:1::4
80.249.99.130
So that website is available via 2 addresses, your IPV4 and 6 which defaults to IPV6 if it's available.
Of course, just putting 2a02:68:1::4 into Google Chrome doesn't do the same as putting in 80.249.99.130, it searches for 2a02:68:1::4. Anyone with an IPV6 only connection will be able to view thinkbroadband (which has an IPV6 speedtester btw) but also, so will anyone with an IPV4 only connection.
Re: IPv6 when?
14-02-2011 11:26 PM
Quote from: David
Quote from: richandsian
Quote from: David As far as I'm aware, Netgear offer *no* IPV6 enabled routers.
I believe my DGND3300 does... unless Netgear were just taking the mickey when they left the configuration page in for it.
Quite right, I just checked. If you head over to www.tunnelbroker.net you can sign up and add the DNS to the 6to4 tunnel and get IPV6 now, although you'll need to notify the site every time you disconnect unless you have a static IP. Be interesting to know if your router firewall works with IPV6 traffic to, the Netgear site doesn't even mention IPV6 and (if I'm reading this right) the config page is actually hidden?
Out of interest, what CPE are you looking at PlusNet? Thompson, Netgear, Zyxel, Cisco, Billion?
[Moderator's note by Jim (Oldjim) link fixed ]
Just seen this on the Netgear site: http://kb.netgear.com/app/answers/detail/a_id/18631/kw/WNR1000v2
WNR1000v2 Firmware Version 1.1.2.28
New Features:
1. Support IPv6 and passed IPv6 ready logo certificate.
I think this is the router that Plusnet are now shipping for those on the FTTC trial, could those on that trial perhaps be used in a trial for IPv6 at some point in the future?
Re: IPv6 when?
18-02-2011 3:14 PM
Quote from: benoh I dont see your v6 prefix in the routing table atm, perhaps you could announce it
Its out there now
Re: IPv6 when?
18-02-2011 9:06 PM
Tracing the route to 2A02:16C8::1
1 2001:7F8:4:FFFF::2 4 msec 0 msec 4 msec
2 2001:7F8:4:1::1AD7:1 4 msec 8 msec 12 msec
3 2001:7F8:4::1AD7:1 4 msec 0 msec 0 msec
4 2A02:16C8::5 0 msec 4 msec 0 msec
5 2A02:16C8::1 4 msec 4 msec 4 msec
[corrected address for trace]
Re: IPv6 when?
18-02-2011 9:08 PM
Re: IPv6 when?
18-02-2011 9:38 PM
adw@avatastic:~$ traceroute6 2A02:16C8::1
traceroute to 2A02:16C8::1 (2a02:16c8::1), 30 hops max, 80 byte packets
1 2001:41c8:1:5e2c::1 (2001:41c8:1:5e2c::1) 0.670 ms 0.623 ms 0.613 ms
2 2001:41c8:0:858::2 (2001:41c8:0:858::2) 0.962 ms 1.074 ms 1.209 ms
3 2001:41c8:0:74::1 (2001:41c8:0:74::1) 7.419 ms 7.485 ms 7.635 ms
4 lonap.he.net (2001:7f8:17::1b1b:1) 7.617 ms 7.618 ms 7.725 ms
5 2001:7f8:4::1ad7:1 (2001:7f8:4::1ad7:1) 7.992 ms 8.263 ms 8.140 ms
6 2a02:16c8::5 (2a02:16c8::5) 184.050 ms 167.199 ms 167.298 ms
7 2a02:16c8::1 (2a02:16c8::1) 8.059 ms 8.563 ms 8.393 ms
And from my PN connection (via HE tunnel)
[adw@skynet ~]$ traceroute6 2A02:16C8::1
traceroute6 to 2A02:16C8::1 (2a02:16c8::1) from 2001:470:1f08:5f3::2, 64 hops max, 12 byte packets
1 avatastic-1.tunnel.tserv5.lon1.ipv6.he.net 34.582 ms 33.859 ms 32.419 ms
2 gige-g4-6.core1.lon1.he.net 26.022 ms 36.969 ms 28.057 ms
3 2001:7f8:4::1ad7:1 25.347 ms 26.913 ms 29.016 ms
4 2a02:16c8::5 28.834 ms 27.009 ms 30.479 ms
5 2a02:16c8::1 30.974 ms 29.645 ms 26.330 ms
(edited because I was a dingbat and tracing to the wrong address)
