IPv6 trial
- Trials
- IPv6 Trial
- Re: IPv6 trial
IPv6 trial
04-02-2015 11:35 PM
Is there a method of signup/waiting list for the IPv6 trial?
M
M
3 REPLIES 3
Re: IPv6 trial
05-02-2015 12:34 AM
No.
You will be much better off using the Hurricane Electric IPv6 Tunnel Broker.
I've been using it for two years, and have far fewer problems than the Plusnet IPv6 trialists.
Re: IPv6 trial
11-02-2015 9:07 PM
I'm set up using the tunnel broker but I'm starting to question the usefulness of it! As much as I like having IPv6 addresses on my network, everything that uses a CDN is now actually running slower as I'm not taking advantage of CDNs hosted by PlusNet.
It's very reliable though and still pretty quick, and I've not noticed any connectivity issues with it.
Re: IPv6 trial
12-02-2015 11:42 AM
personally I did use a tunnel before using native, the tunnel was ok, but native is better for sure.
Also the tunnel software I used had a bug where it leaked handles in windows, so luckily I dont have to deal with that anymore.
