IPv6 on TG582n
w23
Fixes: 4
Re: IPv6 on TG582n
Ideally toy need to use the global one assigned to your router (sorry I don't know where you'd find it on that model), alternatively you could probably port forward to a specific computer that you can leave running.
Call me 'w23'
MJN
Seasoned Pro
Fixes: 5
Re: IPv6 on TG582n
If you run ip iplist on the router you should find a GUA address (2a02:16c8:...) auto-configured on the LAN interface.
jelv
Fixes: 10
Re: IPv6 on TG582n
I'm sending you a PM of the output from that.
The address I've tried to use is the full one starting 2a02:16c8
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
MJN
Seasoned Pro
Fixes: 5
Re: IPv6 on TG582n
Received! It's the first address in the second list...
(The second address represents the prefix on the LAN i.e. the whole network.
jelv
Fixes: 10
Re: IPv6 on TG582n
That's the one I'm trying.  Sad
It's responding to IPv4 pings:
MJN
Seasoned Pro
Fixes: 5
Re: IPv6 on TG582n
Ah, yes, I must admit I was only assuming it would actually respond to pings. I was going to suggest that we just need to enable the IPv6 ping responder (as per how you do with IPv4) but it looks like it is already enabled by default. Will need to look into it further...
jelv
Fixes: 10
Re: IPv6 on TG582n
Just found that:
{admin}[service system]=>list
Idx Name             Protocol         SrcPort  DstPort  Group            State
 1 CWMP-C           tcp over ipv4                                       enabled
 2 CWMP-S           tcp over ipv4             51005                     disabled
 3 DHCP-S           udp over ipv4             676                       enabled
 4 DHCPv6-C         udp over ipv6    547      546                       enabled
 5 DHCPv6-R         udp over ipv6             547                       enabled
 6 DHCPv6-S         udp over ipv6             547                       enabled
 7 DNS-C            udp over ipv4             53                        enabled
 8 DNS-S            ip                        53                        enabled
 9 DYNAMIC_DNS                                                          enabled
10 FTP              tcp                       21                        enabled
11 GRE              gre over ipv4                                       disabled
12 HTTP             tcp over ipv4             80                        enabled
13 HTTPI            tcp over ipv4             8080                      disabled
14 HTTPs            tcp over ipv4             443                       enabled
15 IGMP-Proxy       igmp                                                enabled
16 IP6TO4           ipv6 over ipv4                                      disabled
17 IP_COMMANDS                                                          enabled
18 IP_REDIR         icmp                      5                         disabled
19 IPIP             ipencap                                             disabled
20 IPv6_MANAGEMENT  ipv6-icmp                                           enabled
21 MDAP             udp over ipv4             3235                      enabled
22 PING_RESPONDER   icmp                      8                         enabled
23 PINGv6_RESP      ipv6-icmp                 128                       enabled
24 PPTP        enabled
25 Remote-MBus      tcp over ipv4             2006                      disabled
26 RIP              udp over ipv4    520      520                       disabled
27 SLA_ICMP_PING    icmp                      8                         enabled
28 SLA_UDP_PING     udp over ipv4             7                         disabled
29 SNTP             udp over ipv4    123      123                       enabled
30 SSDP             udp over ipv4             1900                      enabled
31 SYSLOG           udp over ipv4             514                       disabled
32 TELNET           tcp                       23                        enabled
33 TFTP-C           udp over ipv4             69                        disabled
34 WEBF             tcp over ipv4             80                        disabled
35 webservice       tcp over ipv4             9000                      disabled
Have you tried to ping me?
brueton
Re: IPv6 on TG582n
TG582n (with USB port) 10.2.0.B works "out of the box".
All I had to change was the username & password.
Your IPv4 address on the public Internet appears to be 81.174.........
Your IPv6 address on the public Internet appears to be 2a02:16c8:......................
Your Internet Service Provider (ISP) appears to be PLUSNET PlusNet PLC
Since you have IPv6, we are including a tab that shows how well you can reach other IPv6 sites. [more info]
Good news! Your current configuration will continue to work as web sites enable IPv6.
Your DNS server (possibly run by your ISP) appears to have IPv6 Internet access.
Your readiness score
10/10 for your IPv6 stability and readiness, when publishers are forced to go IPv6 only
jelv
Fixes: 10
Re: IPv6 on TG582n
Just tried https://mebsd.com/ipv6-ping-and-traceroute
100% packets lost.
@PeteB have you tried setting up a tbb ping monitor on IPv6?
MJN
Seasoned Pro
Fixes: 5
Re: IPv6 on TG582n
Jelv, it seems you need to actually enable the IPv6 ping responder on the WAN interface:
service system ifadd name=PINGv6_RESP intf=Internet
(the 'enabled' reference in that list must just be for the service itself)
PeteB, nice one! Great to see one that 'just works'!
jelv
Fixes: 10
Re: IPv6 on TG582n
Magic!
https://mebsd.com/ipv6-ping-and-traceroute is now getting answers!
jelv
Fixes: 10
Re: IPv6 on TG582n
That looks better:
brueton
Re: IPv6 on TG582n
@jelv
IPv4 ping response enabled from the GUI
Toolbox > Firewall > Allow PING on your WAN interface
IPv6 ping response enabled from the router command line in the way MJN suggested
