Calling all tunnelers...
- Trials
- IPv6 Trial
- Calling all tunnelers...
10-10-2013 10:38 AM
I see occasional mention of such here in the forum and wondered if, like me as a self-confessed 'techy', it was largely being done to aid your own technical understanding of IPv6 with some hands-on. And/or perhaps 'just because' you could? Or even some other reason?
I was also wondering if there is anyone out there that would like to set up a tunnel up but was a bit bewildered about what options are available and/or where to start? There might be merit in member's sharing their experiences and setups to help others climb on board. If there's a demand for it it might be worthwhile going back to basics to cover even what a tunnel even is, nevermind how to set one up...?
Re: Calling all tunnelers...
10-10-2013 11:58 AM
So I dabbled on the IPv6 trial, and I've kept the tunnel service running, but I tend not to make use of the extra abilities offered for the simple reason that I'm not always on the other end of an IPv6 connection. But my personal main, web, and DNS is all IPv6 enabled - no cat !
At work, there doesn't seem to be any enthusiasm for IPv6, not least because I haven't yet worked out how on earth we might manage it. On the other hand, as someone who does get to "look inside" the network, I know all too well just how broken and f***ed up a NATted network is - especially when certain manufacturers (Zyxel take note) decide to add extra "f***-up measures" (randomised port translations so no NAT traversal measures like STUN can ever work) to their NAT with a "never mind that it doesn't work, it's secure" attitude.
10-10-2013 12:32 PM
Quote from: MJN
I would be. I registered for the HE tunnelbroker, after seeing discussion on the other thread, but promptly gave up due to a complete lack of documentation, explanation, or any decent guides and googling being of little help.
10-10-2013 12:35 PM
I somewhat guessed my router HE tunnelbroker configuration but fortunately it worked first time.
I then subsequently read up further on the subject and proved what I had done was correct, although more by luck than judgement.
I'm sure someone here can point you in the right direction.
What modem/router would you be using ?
It might be best if you start a new thread, so as not to clutter this one.
10-10-2013 1:40 PM
I'm using my /48 to broker a /64 to my home static IP.
I'm also doing this over an IPSEC tunnel as I found 6in4 traffic limited to 256kb/s if I left it unencrypted.
VPS is running Debian, home router is running FreeBSD.
Why tunnel? Why not.
I'm also a t-shirt endowed HE Sage, my domains will all work if IPv4 implodes tomorrow, after finding a registrar who'll let me set IPv6 glue.
It just sits there on the router and in the almost 3 days since last reboot It's done:
Recv: 1.6Gb (Total IPv4/IPv6 traffic for the same period: 12.3 Gb)
Xmit: 131.0 Mb (Total IPv4/IPv6 traffic for the same period: 2.0 Gb)
F9 ADSL customer since 2004
F9 FTTP customer since 2024
10-10-2013 2:00 PM
I've not been using the tunnel since I found it appeared to be giving 'Junior' a nice bypass to my Open DNS layer of protection but I may well re-enable since @purleigh has kindly provided an update on the Open DNS situation.
10-10-2013 3:26 PM
Quote from: purleigh @'DaveyH'
A TP-Link WDR3600, which according to their site supports IPv6 with the latest f/w
Though they also say,
Which IPv6 features are supported by TP-LINK routers?
The routers listed above support IPv6 features (such as DHCP, Static, PPPoE and 6to4) which are applied by Internet Service Providers. In the meantime, we are actively researching and developing more transition mechanism technologies step-by-step according to the requirements of customers.
So guessing it doesn't support 6in4, (or can i use 6to4) and will either have to flash dd-wrt/openwrt or just use my PC as the endpoint
10-10-2013 6:35 PM
12-10-2013 2:56 PM
14-10-2013 10:32 AM
Quote from: Krazeh I've been running a HE tunnel ever since the updated firmware for the TG582N with support for IPv6 was released.
Which firmware is that? I tried one or two from these parts which required the manual commands to be entered to create the tunnel but I found the router would reset several times each day. Usually ruining my online car races
I too was interested in what IPv6 was all about and wanted to learn some new stuff.
14-10-2013 2:08 PM
16-10-2013 9:31 AM
16-10-2013 9:54 AM
Tunneling is cool !
