Android + ipv6 = trouble
- Trials
- IPv6 Trial
- Re: Android + ipv6 = trouble
30-12-2013 12:29 PM
It says there are updates waiting but can't download them.
Anybody else having same issues?
30-12-2013 12:34 PM
30-12-2013 12:43 PM
30-12-2013 12:45 PM
You could try installing an app from the online Play store as this 'push' action can sometimes help resolve certain client-side 'pull' issues.
Edit: Ah, I see you're sorted now.
30-12-2013 1:04 PM
Logged in as my normal user and all apps updated fine. I was trying to PUSH an app when I noticed the updates were still trying to download from YESTERDAY, tablet on overnight.
Will reload my ipv6 config again and try to push another app.
30-12-2013 1:14 PM
p6 2001:4860:4860::8888
PING 2001:4860:4860::8888(2001:4860:4860::8888) 56 data bytes
64 bytes from 2001:4860:4860::8888: icmp_seq=1 ttl=54 time=33.0 ms
64 bytes from 2001:4860:4860::8888: icmp_seq=2 ttl=54 time=32.2 ms
64 bytes from 2001:4860:4860::8888: icmp_seq=3 ttl=54 time=32.4 ms
64 bytes from 2001:4860:4860::8888: icmp_seq=4 ttl=54 time=32.1 ms
64 bytes from 2001:4860:4860::8888: icmp_seq=5 ttl=54 time=32.6 ms
--- 2001:4860:4860::8888 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4005ms
rtt min/avg/max/mdev = 32.170/32.505/33.028/0.305 ms
But a push install FAILS on the tablet, have dropped and reconnected the wifi connection, the download is just sitting at 0 (zero) % done.
30-12-2013 1:17 PM
30-12-2013 2:08 PM
EDIT:
OK loaded v4 config, pushed IPCONFIG to tablet and reloaded the v6 config.
The tablet HAS an ip v6 address, and I can ping it from the pc using its v6 address.
Test-ipv6.com shows 10/10 on the tablet.
30-12-2013 6:40 PM
I can install from Amzon or onemobile fine with ipv6 enabled.
Installs (either from the market app or pushed) just sit there downloading at 0%.
31-12-2013 9:30 AM
Is it possible to get a tracert posted?
Don't think android exposes options for disabling IPv6
31-12-2013 11:16 AM
I tried just now pushing the phone copy of Phonesky (the market) on to a tablet and clearing the cache etc. Still just sits there.
Doing a google on it, only shows issues with one phone and it works if you go via a proxy. So not sure what to try next. Anybody know of a free proxy I can try?
05-04-2014 3:22 PM
To disable ipv6 in android
echo 1 > /proc/sys/net/ipv6/conf/wlan0/disable_ipv6
I added it to a startup script.
05-04-2014 3:38 PM
05-04-2014 3:48 PM
Using dns tools I had an ipv6 address fine, I could ping back and forward but play store just refused to download apps using ipv6, Amazon/one mobile were fine.
In the end I just disabled it, life’s too short.
![Wink Wink](/html/@0FA1396AC0773F33E2DC472BB4F75D3C/images/emoticons/wink.gif)
05-04-2014 3:53 PM
