one or two small questions
- Home Phone
- one or two small questions
24-07-2008 8:03 PM
Also when is it better to change (from BT) if we do decide to - early in the new billing period, or nearer the end of a billing period.
Re: one or two small questions
24-07-2008 8:10 PM
Any time will do for the change, the phone and BB use are joined, the first bill is adjusted to get the same date.
BT finalize you account and give you a refund (rental is in advance)
You keep the same number on homephone.
Dont know about VOIP dont use it
24-07-2008 9:20 PM
Plusnet will arrange everything for you. They'll inform BT that you're moving. You'll get a letter from BT telling you that you've requested a move and saying that any services you have on the line (1571, Called Display etc.) will stop (if you want to keep these, you need to sign up with them at PN when you order Home Phone- if you do this there will be no downtime in your services - you can sign up for/remove calling features at any time though). You just ignore the letter if you want to move to PN.
On the day you move you will not notice any change in your phone service. The day following your move you will get a confirmation e-mail from PN advising that the move has happened and you'll be able to access your Home Phone member centre.
There's no "best time" to move as, as pierre said, BT will refund you any overpaid line rental.
The whole process takes about ten days!
25-07-2008 1:25 PM
02-08-2008 1:19 PM
02-08-2008 1:23 PM
The big advantage of PlusNet is that the broadband fault fault team talk to the phone fault team unlike BT.
02-08-2008 1:28 PM
You call PN faults on 0114 296 5188 and they call BT Openreach who repair your line.
If you were with BT, you'd call BT Retail faults on 151 who'd then call BT Openreach to fix your line!
Edit: Oldjim beat me to it!!
Edit 2 : typos
02-08-2008 1:45 PM
02-08-2008 3:18 PM
The actual provider of the service remains as BT?
All this privatisation has gone too far - the tax payer paid for the Post Office to install and maintain all this infrastructure in the first place.
I remember being shown round the local exchange because they were closing it down.
Apparently all those fascinating electromechanical selector switches were no longer cost effective
02-08-2008 3:19 PM
In my case they did the tests and texted me in the afternoon with the outcome. It was back on by the following morning.
05-08-2008 1:26 PM
15-08-2008 3:53 PM
15-08-2008 5:14 PM
Not by Plusnet though.
15-08-2008 5:53 PM
With recession upon us and job losses likely to rise, staff should be far more understanding and polite in their dealings with customers
16-08-2008 1:04 PM
